Api session items zones
Revision as of 12:43, 20 April 2026 by Frank@tygron.nl (talk | contribs) (Replaced content with "Api session items Zone Endpoints. Edit items with event: editorzoning. Default Query: <syntaxhighlight lang="text" copy>https://engine.tygron.com/api/session/items/zones/?f=JSON&token=API_TOKEN</syntaxhighlight> Example Response: <syntaxhighlight lang="text" copy>[ ]</syntaxhighlight> ==Limit Queries== version=100: <syntaxhighlight lang="text" copy>https://engine.tygron.com/api/session/items/zones/?version=100&token=API_TOKE...")
Default Query:
Example Response:
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/zones/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/zones/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/zones/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/zones/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/zones/?crs=LOCAL&token=API_TOKEN
bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/zones/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/zones-foo/?crs=3857&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/zones/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/zones/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/zones/?f=HTML&token=API_TOKEN
JSON:
GEOJSON:
https://engine.tygron.com/api/session/items/zones/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/zones/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/zones/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/zones/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/zones/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/zones/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/zones/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/zones/?f=ZIPSMILE&token=API_TOKEN
Api Model CategoryZone
API Model description of CategoryZone
Name Type Description
allowedCategories Category[]
attributes Map<String,double[]>
center Point
excelID int Excel Sheet ID
excelUpdated boolean
id int
maquetteOverride Map<String,double[]>
name String
outline Outline
parentZoneID int Zone ID
permitterID int Stakeholder ID
polygons MultiPolygon
sourceIDs int[] Source ID
version int
Api Model Zone
API Model description of Zone
center Point
id int
name String
outline Outline
version int
Api Model ZoneAttribute
API Enumeration description of ZoneAttribute
Name Description
MAX_BUILDING_HEIGHT
MAX_ROOF_GUTTER_HEIGHT
MAX_FLOORS
MIN_FLOORS
AMOUNT_FLOORS
MAX_BUILDING_PCT
MONUMENTAL
