Api session items netsettings
Revision as of 12:37, 20 April 2026 by Frank@tygron.nl (talk | contribs)
Api session items Net Settings Endpoints.
Edit items with event: editornetsetting.
Default Query:
https://engine.tygron.com/api/session/items/netsettings/?f=JSON&token=API_TOKEN
Example Response:
  "id" : 0,
  "value" : "1.0",
  "version" : 1
  "id" : 1,
  "value" : "true",
  "version" : 2
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/netsettings/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/netsettings/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/netsettings/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/netsettings/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/netsettings/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/netsettings/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/netsettings/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/netsettings/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/netsettings/?f=ZIPSMILE&token=API_TOKEN
Api Model NetSetting
API Model description of NetSetting
Name Type Description
id int
value String
version int
Api Model Type (NetSetting)
API Enumeration description of Type
Name Description
CLUSTER_FRACTION_CONNECTED
REQUIRE_UTILITY_CORPORATION_APPROVAL
CLUSTER_MODELS_ENABLED
LOAD_TO_NODE_LINES_ENABLED
FIRST_CONNECT_ACCEPT
HEAT_NETWORK_OWNER_ID
ELECTRICITY_NETWORK_OWNER_ID
GAS_NETWORK_OWNER_ID
INTERNET_NETWORK_OWNER_ID
SEWER_NETWORK_OWNER_ID
ELECTRICITY_FLOW_ATTRIBUTE
GAS_FLOW_ATTRIBUTE
HEAT_FLOW_ATTRIBUTE
INTERNET_FLOW_ATTRIBUTE
SEWER_FLOW_ATTRIBUTE
ELECTRICITY_ACTIVE
GAS_ACTIVE
HEAT_ACTIVE
INTERNET_ACTIVE
SEWER_ACTIVE
RESTRICT_TO_NET_OVERLAY
