Api session items netloads
Api session items Net Loads Endpoints.
Edit items with event: editornetload.
Default Query:
https://engine.tygron.com/api/session/items/netloads/?f=JSON&token=API_TOKENExample Response:
"addressIDs" : [ ],
"attributes" : {
"ROOT_LOAD" : [ 1.0 ]
"buildingID" : -1,
"clusterID" : -1,
"connectionState" : "NOTHING",
"id" : 0,
"maquetteOverride" : null,
"name" : "NetLoad 0",
"netType" : "ELECTRICITY",
"nodeID" : 0,
"point" : null,
"sourceIDs" : [ ],
"version" : 11
"addressIDs" : [ 90 ],
"attributes" : {
"TYPE" : [ 5.0 ]
"buildingID" : 444,
"clusterID" : 0,
"id" : 1,
"name" : "NetLoad 1",
"nodeID" : 2,
"point" : null,
"sourceIDs" : [ 12 ],
"version" : 12
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/netloads/?version=100&token=API_TOKENPseudo-Mercator:
https://engine.tygron.com/api/session/items/netloads/?crs=3857&token=API_TOKENDegrees:
https://engine.tygron.com/api/session/items/netloads/?crs=4326&token=API_TOKENAmersfoort / RD New:
https://engine.tygron.com/api/session/items/netloads/?crs=28992&token=API_TOKENLocal Coordinates:
https://engine.tygron.com/api/session/items/netloads/?crs=LOCAL&token=API_TOKENbbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/netloads/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFOO:
https://engine.tygron.com/api/session/items/net_loads-foo/?crs=3857&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/netloads/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/netloads/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/netloads/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/netloads/?f=JSON&token=API_TOKENGEOJSON:
https://engine.tygron.com/api/session/items/netloads/?f=GEOJSON&token=API_TOKENGPKG:
https://engine.tygron.com/api/session/items/netloads/?f=GPKG&token=API_TOKENDXF:
https://engine.tygron.com/api/session/items/netloads/?f=DXF&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/netloads/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/netloads/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/netloads/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/netloads/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/netloads/?f=ZIPSMILE&token=API_TOKENApi Model NetLoad
API Model description of NetLoad
| Name | Type | Description |
| addressIDs | int[] | Address ID |
| attributes | Map<String,double[]> | |
| buildingID | int | Building ID |
| clusterID | int | Net Cluster ID |
| connectionState | TimeState | |
| id | int | |
| maquetteOverride | Map<String,double[]> | |
| name | String | |
| netType | NetType | |
| nodeID | int | Net Node ID |
| point | Point | |
| sourceIDs | int[] | Source ID |
| version | int |
