Api session event editor weather set flood overlay
Revision as of 13:42, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorweather/set_flood_overlay.
Description: Set a specific visualization Overlay for a specified Weather.
0 REQUIRED (WEATHER Integer ID or multiple values in array [1, 2, 3]) Weather ID
1 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay ID allowed for Weather visualization input
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorweather/set_flood_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorweather/set_flood_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorweather/set_flood_overlay/", options)
