Api session event editor trigger add
API Endpoint: editortrigger/add.
Description: Add new Trigger
| 0 | OPTIONAL | (Timing or multiple values in array [a, b, c]) | Timing[] |
curl 'https://engine.tygron.com/api/session/event/editortrigger/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '""'JavaScript example POST:
body: '""'
fetch("https://engine.tygron.com/api/session/event/editortrigger/add/", options)
