Api session event editor stakeholder set short name
Revision as of 13:41, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorstakeholder/set_short_name.
Description: Set Short Name
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (String) String
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/set_short_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'
JavaScript example POST:
 body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/set_short_name/", options)
