Api session event editor sound set filename
Revision as of 13:40, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsound/set_filename.
Description: Set Filename
0 REQUIRED (SOUND Integer ID) Sound
1 REQUIRED (String) String
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsound/set_filename/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'
JavaScript example POST:
 body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorsound/set_filename/", options)
