Api session event editor sound remove
Revision as of 13:40, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsound/remove.
Description: Remove existing Sound
0 REQUIRED (SOUND Integer ID or multiple values in array [1, 2, 3]) Sound
curl 'https://engine.tygron.com/api/session/event/editorsound/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorsound/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorsound/remove/", options)
