Api session event editor setting set decimals
API Endpoint: editorsetting/set_decimals.
Description: Set Decimals
| 0 | REQUIRED | (Integer number) | Integer |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_decimals/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_decimals/", options)
