Api session event editor setting set currency
Revision as of 13:40, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsetting/set_currency.
Description: Set Currency
0 REQUIRED (Enumeration) TCurrency POUND_BRITISH, EURO or DOLLAR_US
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_currency/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"DOLLAR_US"'
JavaScript example POST:
 body: '"DOLLAR_US"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_currency/", options)
