Api session event editor scenario set limit neighborhoods
Revision as of 13:40, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorscenario/set_limit_neighborhoods.
Description: Set Limit Neighborhood
0 REQUIRED (SCENARIO Integer ID) Scenario
1 REQUIRED (NEIGHBORHOOD Integer ID or multiple values in array [1, 2, 3]) Neighborhood
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_limit_neighborhoods/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_limit_neighborhoods/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_limit_neighborhoods/", options)
