Api session event editor scenario add
Revision as of 13:39, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorscenario/add.
Description: Add new Scenario.
200 Integer (Scenario ID)
curl 'https://engine.tygron.com/api/session/event/editorscenario/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'
JavaScript example POST:
 body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/add/", options)
