Api session event editor parametric generate
API Endpoint: editorparametric/generate.
Description: Generate
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID) | Parametric Design |
| 200 | PDResult (PDResult) |
curl 'https://engine.tygron.com/api/session/event/editorparametric/generate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorparametric/generate/", options)
