Api session event editor panel set point
API Endpoint: editorpanel/set_point.
Description: Set Point
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | OPTIONAL | (Point with crs: EPSG:3857) | Point |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "" ]'JavaScript example POST:
body: '[ 1, "" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_point/?crs=3857", options)
