Api session event editor panel set for everyone
Revision as of 13:38, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorpanel/set_for_everyone.
Description: Set For Everyone
0 REQUIRED (PANEL Integer ID) Panel
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_for_everyone/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_for_everyone/", options)
