Api session event editor panel set answer contents
Revision as of 13:38, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorpanel/set_answer_contents.
Description: Set Answer (Panel) Contents
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (Integer number) Integer
2 REQUIRED (String) String
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_answer_contents/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Text" ]'
JavaScript example POST:
 body: '[ 1, 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_answer_contents/", options)
