Api session event editor panel remove answer
Revision as of 13:38, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorpanel/remove_answer.
Description: Remove Answer (Panel)
0 REQUIRED (PANEL Integer ID or multiple values in array [1, 2, 3]) Panel
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/remove_answer/", options)
