Api session event editor netsetting set cluster fraction connected
Revision as of 13:38, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editornetsetting/set_cluster_fraction_connected.
Description: Set Cluster Fraction Connected
0 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '99'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '82'
JavaScript example POST:
 body: '99'
fetch("https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/", options)
