Api session event editor netload remove node
API Endpoint: editornetload/remove_node.
Description: Remove Node
| 0 | REQUIRED | (NET_LOAD Integer ID) | Net Load |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/remove_node/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetload/remove_node/", options)
