Api session event editor netload remove building
Revision as of 13:37, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editornetload/remove_building.
Description: Remove Building
0 REQUIRED (NET_LOAD Integer ID) Net Load
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/remove_building/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetload/remove_building/", options)
