Api session event editor netload add and set node
Revision as of 13:37, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editornetload/add_and_set_node.
Description: Add And Set Node
0 REQUIRED (NET_LOAD Integer ID) Net Load
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658741.8369602589, 6799363.666053166 ]
Curl example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658653.180243304, 6799405.490406346 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658741.8369602589, 6799363.666053166 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857", options)
