Api session event editor netfunction add
API Endpoint: editornetfunction/add.
Description: Add new Net Function
| 0 | REQUIRED | (Enumeration) | NetType | ELECTRICITY, GAS, HEAT, INTERNET or SEWER |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editornetfunction/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"ELECTRICITY"'JavaScript example POST:
body: '"ELECTRICITY"'
fetch("https://engine.tygron.com/api/session/event/editornetfunction/add/", options)
