Api session event editor netcluster remove all clusters
Revision as of 13:36, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editornetcluster/remove_all_clusters.
Description: Remove All Clusters
0 REQUIRED (Enumeration) NetType ELECTRICITY, GAS, HEAT, INTERNET or SEWER
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetcluster/remove_all_clusters/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"ELECTRICITY"'
JavaScript example POST:
 body: '"ELECTRICITY"'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/remove_all_clusters/", options)
