Api session event editor levee set default width
Revision as of 13:35, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorlevee/set_default_width.
Description: Set Default Width
0 REQUIRED (LEVEE Integer ID) Levee
1 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_width/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 0 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_width/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 75 ]'
JavaScript example POST:
 body: '[ 1, 0 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_default_width/", options)
