Api session event editor levee set angle degrees
Revision as of 13:35, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorlevee/set_angle_degrees.
Description: Set Angle Degrees
0 REQUIRED (LEVEE Integer ID) Levee
1 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 23 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 90 ]'
JavaScript example POST:
 body: '[ 1, 23 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/", options)
