Api session event editor levee add
Revision as of 13:35, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorlevee/add.
Description: Add new Levee
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorlevee/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'
JavaScript example POST:
 body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/add/", options)
