Api session event editor indicator set target
Revision as of 13:34, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorindicator/set_target.
Description: Set a target value of an Indicator for a Sceanrio. A target index value is required.
0 REQUIRED (SCENARIO Integer ID) Scenario ID
1 REQUIRED (INDICATOR Integer ID) Indicator ID
2 REQUIRED (Integer number) Target index
3 REQUIRED (Floating point number) Target value
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_target/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1, 95 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_target/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1, 73 ]'
JavaScript example POST:
 body: '[ 1, 1, 1, 95 ]'
fetch("https://engine.tygron.com/api/session/event/editorindicator/set_target/", options)
