Api session event editor geotiff set geotiff url
Revision as of 13:34, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorgeotiff/set_geotiff_url.
Description: Update existing GeoTIFF Item from Web URL.
0 REQUIRED (GEO_TIFF Integer ID or multiple values in array [1, 2, 3]) GeoTIFF ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Web URL
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Uploader
3 OPTIONAL (String or multiple values in array ["a", "b", "c"]) CRS Override (optional)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/set_geotiff_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Web URL 1", "Uploader 1", "" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/set_geotiff_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Web URL 1", "Web URL 2", "Web URL 3" ], [ "Uploader 1", "Uploader 2", "Uploader 3" ], "" ]'
JavaScript example POST:
 body: '[ 1, "Web URL 1", "Uploader 1", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/set_geotiff_url/", options)
