Api session event editor geotiff export
API Endpoint: editorgeotiff/export.
Description: Export GeoTIFF. For files larger than 2GB, use the Stream API.
| 0 | REQUIRED | (GEO_TIFF Integer ID) | GeoTIFF ID |
| 200 | byte[] (byte array) |
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/export/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/export/", options)
