Api session event editor geolink set mapping
API Endpoint: editorgeolink/set_mapping.
Description: Map orginal Attribute name to a new name in the created feature.
| 0 | REQUIRED | (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) | CustomGeo Link IDs | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Orginal Attribute Names | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | New Attribute Names |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_mapping/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Orginal Attribute Name 1", "New Attribute Name 1" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_mapping/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Orginal Attribute Name 1", "Orginal Attribute Name 2", "Orginal Attribute Name 3" ], [ "New Attribute Name 1", "New Attribute Name 2", "New Attribute Name 3" ] ]'JavaScript example POST:
body: '[ 1, "Orginal Attribute Name 1", "New Attribute Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/set_mapping/", options)
