Api session event editor excelsheet add
Revision as of 13:32, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorexcelsheet/add.
Description: Add new Excel Sheet
0 REQUIRED (String) Name
1 REQUIRED (byte or multiple values in array [a, b, c]) Byte array content
2 REQUIRED (String) Uploader Name
200 Integer (Excel ID)
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Name", 1, "Uploader Name" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Name", [ 1, 2, 3 ], "Uploader Name" ]'
JavaScript example POST:
 body: '[ "Name", 1, "Uploader Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorexcelsheet/add/", options)
