Api session event editor cinematic add keypoint
API Endpoint: editorcinematic/add_keypoint.
Description: Add Keypoint
| 0 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint/", options)
