Api session event editor area add with attribute
Revision as of 13:31, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorarea/add_with_attribute.
Description: Add With Attribute
0 REQUIRED (String) String
1 REQUIRED (Floating point number) Double
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", 34 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", 40 ]'
JavaScript example POST:
 body: '[ "Text", 34 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/", options)
