Api session event editor area set active
Revision as of 13:31, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorarea/set_active.
Description: Set Area active
0 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Area
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Boolean[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST:
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/set_active/", options)
