Api session event editor start map creation
API Endpoint: eventeditor/start_map_creation.
Description: Set the Project's georeference center point to the provided coordinates and begin the process of automatically load in available data.
| 0 | REQUIRED | (Floating point number) | Center point (Longitude or X coordinate) | |
| 1 | REQUIRED | (Floating point number) | Center point (Latitude or Y coordinate) | |
| 2 | OPTIONAL | (MultiPolygon with crs: EPSG:3857) | Optional: Limit data loading to this Polygon | |
| 3 | OPTIONAL | (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) | Optional: Area of Interest Polygons |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editor/start_map_creation/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 10, 93, "", "" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editor/start_map_creation/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 7, 49, "", "" ]'JavaScript example POST:
body: '[ 10, 93, "", "" ]'
fetch("https://engine.tygron.com/api/session/event/editor/start_map_creation/?crs=3857", options)
