Api session event editor overlay set key value
API Endpoint: editoroverlay/set_key_value.
Description: Change a key for a specified Overlay. The Overlay must be an Overlay which makes use of keys to read attributes of geographical items, as input for its calculation. Note to change attribute values use set_attribure instead.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to a grid Overlay) | |
| 1 | REQUIRED | (String) | Key name | |
| 2 | REQUIRED | (String) | Attribute to look for |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_key_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Key name", "Attribute to look for" ]'JavaScript example POST:
body: '[ 1, "Key name", "Attribute to look for" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_key_value/", options)
