Api session event editor overlay set water mode
Revision as of 13:02, 13 April 2026 by Maxim@tygron.com (talk | contribs)
API Endpoint: editoroverlay/set_water_mode.
Description: Set Water Mode
0 REQUIRED (OVERLAY Integer ID) Overlay
1 REQUIRED (Enumeration) Mode ACCURACY, AVERAGE or SPEED
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_water_mode/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SPEED" ]'
JavaScript example POST:
 body: '[ 1, "SPEED" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_water_mode/", options)
