Api session event editor overlay set rasterization
API Endpoint: editoroverlay/set_rasterization.
Description: Set the type of rasterization a specified AVG or Distance Overlay should do.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to an AVG or Distance Overlay) | |
| 1 | REQUIRED | (Enumeration) | Rasterization type: FIRST, MIN, MAX, SINGLE_LAYER, GRID | FIRST, MAX, MIN, SINGLE_LAYER or GRID |
| 2 | OPTIONAL | (Enumeration) | MapLink (will only affect the SINGLE_LAYER rasterization type): BUILDINGS, TERRAINS, AREAS, NEIGHBORHOODS |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_rasterization/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "FIRST", "" ]'JavaScript example POST:
body: '[ 1, "FIRST", "" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_rasterization/", options)
