Api session event editor overlay set parent
API Endpoint: editoroverlay/set_parent.
Description: Set a parent Overlay for a specified Overlay. This will cause the specified Overlay to be a subselectable Overlay of the parent. It is not possible to set an Overlay which has a parent itself as a parent of another Overlay.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID | |
| 1 | REQUIRED | (Integer number) | Overlay ID of parent (Overlay without a parent should have their parent Overlay ID set to -1) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_parent/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_parent/", options)
