Api session event editor overlay set overlay area
API Endpoint: editoroverlay/set_overlay_area.
Description: Add or remove specified Area to or from a specified AREAS Overlay. Unincluded Area which are already related to the Overlay will remain related. Unincluded Area which are not related to the Overlay will remain unrelated.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to an AREAS Overlay) | |
| 1 | REQUIRED | (AREA Integer ID or multiple values in array [1, 2, 3]) | Array of Area IDs | |
| 2 | REQUIRED | (true, false) | Should be added to the Overlay (false removes the Area from the Overlay) | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_area/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, false ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_area/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], true ]'JavaScript example POST:
body: '[ 1, 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_area/", options)
