Api session event editor overlay set avg distance
API Endpoint: editoroverlay/set_avg_distance.
Description: Set the averaging distance for a specified AVG Overlay.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to an AVG Overlay) | |
| 1 | REQUIRED | (Floating point number) | Averaging distance |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 21 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 38 ]'JavaScript example POST:
body: '[ 1, 21 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/", options)
