Api session event editor overlay remove prequel
API Endpoint: editoroverlay/remove_prequel.
Description: Remove a Grid Overlay's prequel Overlay.
| 0 | REQUIRED | (OVERLAY Integer ID) | Grid Overlay ID | |
| 1 | REQUIRED | (String) | Prequel Type Name |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_prequel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Prequel Type Name" ]'JavaScript example POST:
body: '[ 1, "Prequel Type Name" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/remove_prequel/", options)
