Api session event editor source set uploader
Revision as of 12:01, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsource/set_uploader.
API Endpoint name is Api session event editor source set uploader.
Use this endpoint to Set Uploader
0 REQUIRED (SOURCE Integer ID) Source
1 REQUIRED (String) String
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorsource/set_uploader/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'
JavaScript example POST:
 body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/set_uploader/", options)
