Api session event editor source add service
Revision as of 12:01, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsource/add_service.
API Endpoint name is Api session event editor source add service.
Use this endpoint to Add Service
0 REQUIRED (Enumeration) GeoFormat BGT_GML, CYCLO_IMAGE, DXF, ESRI_IMAGE, ESRI_JSON, GEOJSON, GEOPACKAGE, GEOTIFF, I3S, OSM, WCS_TIFF, WFS_GML, WFS_JSON or WMS_IMAGE
1 REQUIRED (String) String
2 REQUIRED (String) String
3 REQUIRED (String) String
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorsource/add_service/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GEOJSON", "Text", "Text", "Text" ]'
JavaScript example POST:
 body: '[ "GEOJSON", "Text", "Text", "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/add_service/", options)
