Api session event editor source add catalog
Revision as of 12:00, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsource/add_catalog.
API Endpoint name is Api session event editor source add catalog.
Use this endpoint to Add Catalog
0 REQUIRED (Enumeration) GeoCatalog CSW or ESRI
1 REQUIRED (String) String
2 REQUIRED (String) String
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorsource/add_catalog/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "CSW", "Text", "Text" ]'
JavaScript example POST:
 body: '[ "CSW", "Text", "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/add_catalog/", options)
