Api session event editor setting wizard finished
Revision as of 12:00, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsetting/wizard_finished.
API Endpoint name is Api session event editor setting wizard finished.
Use this endpoint to Wizard Finished
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/wizard_finished/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'
JavaScript example POST:
 body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorsetting/wizard_finished/", options)
