Api session event editor setting set permission popup active
Revision as of 12:00, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsetting/set_permission_popup_active.
API Endpoint name is Api session event editor setting set permission popup active.
Use this endpoint to Set Permission Popup Active
0 REQUIRED (true, false) Boolean true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_permission_popup_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_permission_popup_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'false'
JavaScript example POST:
 body: 'true'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_permission_popup_active/", options)
