Api session event editor scenario set description
API Endpoint: editorscenario/set_description.
API Endpoint name is Api session event editor scenario set description.
Use this endpoint to Set Description
| 0 | REQUIRED | (SCENARIO Integer ID) | Scenario | |
| 1 | REQUIRED | (String) | String |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'JavaScript example POST:
body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_description/", options)
