Api session event editor scenario set name
Revision as of 11:59, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorscenario/set_name.
API Endpoint name is Api session event editor scenario set name.
Use this endpoint to Set new name of existing Scenario
0 REQUIRED (SCENARIO Integer ID or multiple values in array [1, 2, 3]) Scenario
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text 1" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'
JavaScript example POST:
 body: '[ 1, "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_name/", options)
