Api session event editor parametric generate
Revision as of 11:59, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorparametric/generate.
API Endpoint name is Api session event editor parametric generate.
Use this endpoint to Generate
0 REQUIRED (PARAMETRIC_DESIGN Integer ID) Parametric Design
200 PDResult (PDResult)
curl 'https://engine.tygron.com/api/session/event/editorparametric/generate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorparametric/generate/", options)
